I am re powering my boat with a 2005-F90TLR 4 stroke Yamaha. I picked up a used Yamaha 10 pin main harness and control assembly from a 2001 boat. All is good except for connecting the new Yamaha tach assembly gauge ( 6Y7-83540-80-00). I am having trouble connecting the gauge to the trim harness. I figured out that instead of the proper trim harness (6Y5-83653-10-00), I have an older oil transfer harness from a 2 stroke (6R3-85721-80-00). The blue connector clipped into the engine end (4 pink wires) just fine and has the same 4 but different colored wires, so I am thinking that it should work fine. All I really need to know now, is the conversion coloring coding that connects to the clip connector on the new tach gauge. The 4 wires coming from the oil transfer harness are black, black with a red stripe, blue, and light brown. To which colored wires on the gauge clip connection should they each connect to?
Wire color coding (Yamaha Tach Gauge)?
This might help, but you really need to get the service manual for exact colors:
https://maxrules.com/fixyamahawiring.php
2011 F50TLR, 2010 G3 V167C
Originally posted by rejesterd View PostThis might help, but you really need to get the service manual for exact colors:
What am I missing?
From the SM:
I am hooking up the 6Y7-83540 tach to a 2019 F40LA tiller model and looking at the above diagram, using a 6Y5-83653 cable and then providing +12 V to the yellow, yellow/red, and blue wires, -12V to the blacks on the tach, the only other connection I need to make would be to run a wire from the green in the motor to the green on the tach for the tach signal. I read in another post that the green can be found in the tiller handle. Is this reading of the wiring diagram correct? Thanks, Mike
You are looking at the wrong diagram. That diagram pertains to a remote con*****ed model. You say that yours has a tiller handle.
Please don't piggyback on another mans post. Start your own please. When you do please give us the completer serial number for your motor. There many years of F40LA out there.
Originally posted by boscoe99 View PostYou are looking at the wrong diagram. That diagram pertains to a remote con*****ed model. You say that yours has a tiller handle.
ÂÂÂ
