Last time I was out on the water, I noticed the engine would throttle before the forward gear was engaged, causing the boat to jolt suddenly. Not sure if it is as simple as adjusting shift/throttle cables. Any suggestion are appreciated.
2005 VMAX HPDI Shift/Throttle Issue
Strange. What is your rpm at idle in neutral (or at least when you think it's in neutral)?
Also, what size is this? The 200 hp?
And did it happen while you had your hand on the throttle control (even if you hadn't moved it yet)?2011 F50TLR, 2010 G3 V167C
But regardless.. sounds like the shift slider/spring or something else in the lower unit. I don't see how your shift linkage could be THAT far off where it would suddenly put the thing in gear like that.2011 F50TLR, 2010 G3 V167C
Originally posted by quar5713 View PostLast time I was out on the water, I noticed the engine would throttle before the forward gear was engaged, causing the boat to jolt suddenly. Not sure if it is as simple as adjusting shift/throttle cables. Any suggestion are appreciated.
I think he got a high idle problem not a shifting problem.
That is my interpretation of his post. Hopefully he will clarify.
I believe what the man is saying is that the rpm at idle is high and when he puts in gear the boat takes off faster than it should. "I notice the engine would throttle BEFORE the foward gear was engaged"
Thanks to all for your input. Just to clarify, it may be better described as “engine would throttle simultaneously to engaging the forward gear”. Once in gear it runs at a higher RPM than normal. When I try to ease off the throttle, it shifts out of gear. I’m unable to gradually increase/decrease speed which makes it more difficult loading on the trailer at the ramp. I am currently out of the country on an international assignment; I will check the engine idle speed with a tachometer once I’m back stateside toward the end of the month and report my findings. Thanks again.
BTW 200 HP2005 Pathfinder 2200V
2005 Yamaha 200HP VMAX HPDI
ÂÂÂÂÂÂ
