Runs fine at low RPMs but once wide open for more than about a minute the alarm sounds and the engine bogs down (shakes) and slows down. I have to run it at idle for about a minute till the alarm goes off. Then it will run wide open for about a minute and then the same thing happens.
Is this an overheat alarm, a bad oil level sensor, or is it a fuel filter issue? Any help would be appreciated.
Engine is not used in salt water.
