In attempting to remove my aprons, I have stripped out a couple of the sockets of the bolts, yes I am using a metric "Allen" wrench. How do I get them out?
F200XB & LF200XB Apron screws are too tight & hex socket is shallow
bummer.
I would try a left-handed drill bit-
1/4" may not be too hard to find,
or a tad smaller or larger
ideally as it bites, the screw will back out
and then you just have to buy a new screw @ $3 per
but shouldn't chew up the apron
or the threaded holes in the upper casing
the end of the allen wrench is usually rounded some on the end to make it easier to slide into the hole.
you might try grinding the end flat to give it better bite all of the way inside the screw head.
also make sure the hole is clean so the wrench fits in as far as it can get
If the allen set is a cheaper set, I've found in the past that their sizes aren't always completely true and it leads to that problem. Try the next half size larger or a standard size - see if they fit better. Otherwise, I assume there's not enough room to cut a slot for a straight screwdriver bit and a manual impact driver? The reverse bit is a good idea... or an easy out set. Also, spray some PB Blaster in there a few times over the course of a day or two - can't hurt.2000 Yamaha OX66 250HP SX250TXRY 61AX103847T
Originally posted by DennisG01 View PostIf the allen set is a cheaper set, I've found in the past that their sizes aren't always completely true and it leads to that problem. Try the next half size larger or a standard size - see if they fit better. Otherwise, I assume there's not enough room to cut a slot for a straight screwdriver bit and a manual impact driver? The reverse bit is a good idea... or an easy out set. Also, spray some PB Blaster in there a few times over the course of a day or two - can't hurt.
if the next size up does not fit, try some metric ones.
and do not feel hitting on them is bad to get them in there.
if all else fails take a file to one that almost fits to take off a little on each flat side.
anything to get the old out and buy new to go back in
Thanks for all the comments. I am a tool guy & only use high quality tools (cheap tools are a fools ****). It appears that these bolts are coated with a thread locker compound & that is the problem. The screws back out very hard. I have rounded out a couple of the screws & an Easy Out saved the day. Instead of a 5mm sock head, I am considering replacing them with 316 ss hex head cap screws with a flat & a lock washer. Does anyone see a problem with that?
edit:
Interesting the word "****" is blocked with ****. I did not swear. **** This is crazy again blocked, g a m eLast edited by TAEZZARS; 05-05-2019, 10:49 AM.
I assume Yamaha thinks that flat black button head looks "unobtrusive"
if you like the looks of whatever you use ......
fwiw I goop those screws with waterproof grease when i Install
I don't think they are at risk of vibrating loose / backing out
Originally posted by TAEZZARS View PostThanks for all the comments. I am a tool guy & only use high quality tools (cheap tools are a fools ****). It appears that these bolts are coated with a thread locker compound & that is the problem. The screws back out very hard. I have rounded out a couple of the screws & an Easy Out saved the day. Instead of a 5mm sock head, I am considering replacing them with 316 ss hex head cap screws with a flat & a lock washer. Does anyone see a problem with that?
edit:
You should have some stud left sticking out.
Take a heat gun to the stud (which is in aluminum), that should loosen the locker, then spin out the stud out with a vise grip.
Or if you have a MIG welder, plug weld a nut to the stud, the spin it out-No additional heat required..
*Might use a lower strength locker if you think you need it. Some of Yamaha's Locker (for stators, etc), is STRONG stuff..Last edited by TownsendsFJR1300; 05-05-2019, 04:26 PM.Scott
Worse case scenario, drill the head off and remove the apron.
"I have rounded out a couple of the screws & an Easy Out saved the day. Instead of a 5mm sock head, I am considering replacing them with 316 ss hex head cap screws with a flat & a lock washer. Does anyone see a problem with that?"
I am not sure what metal they screw into, but coating them should help keep it from sticking
sounds like he already got them out, just asking about putting SS hex heads back in
I don't see anything else but aluminum it can be as it's pretty much into the mid section, no?
Originally posted by pstephens46 View Post
Did the originals rust? Why stainless? Stainless fasteners have their own issues.
I have wire brushed all the locker off the threads & am using the good ones again with blue grease just to hold the cowlings in place. When I get to town, I will get the stainless hardware & use the blue grease, which will prevent a lot of the alum/stainless corrosion.
Here is a photo of some of the bolts, you can see that I took a die grinder to one.
ÂÂÂÂÂ
