Looking to remount motor after rebuilding the til/trim unit, had to loosen bracket,now I would like to use the proper material to make sure the bolts are water tight. Thanks for your input!
motor mounting bolts sealant... the best to use
There's really no such thing as "best" as there's multiple manufacturer's that make quality products. The 3M4200 is good stuff (DON'T use 5200)... It's not UV stable, but given the location, it's not really a big deal. BoatLife makes great products, too... either the LifeSeal or LifeCaulk (longer lasting, but takes longer to set). Bostik and Sikoflex are also excellent, although I can't quite remember the exact variant in those two companies. Personally, I've only been using the BoatLife products for the past 15 years as this is pretty much all they do. But that, in and of itself, doesn't make them 'the best', either.2000 Yamaha OX66 250HP SX250TXRY 61AX103847T
Organic silicon and aluminum do not play well together. Something in the organic silicon sealant, be it acetic acid or ammonia will cause aluminum corrosion.
I am told that an inorganic silicon is fine. As DennisG01 said, Sikoflex, I was told that was inorganic silicon sealant.If its got teats or tires, you bound to have trouble with it....
Originally posted by FabricGATOR View PostOrganic silicon and aluminum do not play well together. Something in the organic silicon sealant, be it acetic acid or ammonia will cause aluminum corrosion.
I am told that an inorganic silicon is fine. As DennisG01 said, Sikoflex, I was told that was inorganic silicon sealant.2000 Yamaha OX66 250HP SX250TXRY 61AX103847T
Originally posted by DennisG01 View Post
Do you know if this is a 'for real' thing... as it really happens in real world situations? Or is more of a here-say thing or possibly just in a laboratory under very extreme conditions like much higher concentrations of 'acid'? The reason I ask is that I have never seen evidence of this happening (including the marina I work at part time) with either the BoatLife or 3M products. But then, I don't know their full composition, either. But then, I was never worried about it since it always worked fine
I do remember many years ago when people would use silicone sealant to caulk around there windshield in cars when they had a leak and cause those areas to rust out even faster, but that was not dealing with aluminum2000 Yamaha OX66 250HP SX250TXRY 61AX103847T
Upon removing the sealant I noted a extra amount of corrosion that was abnormal. I remembered that back in the day, silicone sealant was used in aircraft window installation until it was found that the acetic acid formed when it was curing and if used on aluminum, it accelerated corrosion.
Some silicone sealants have been reformulated but what ever was used to seal these engine mounting hole was a poor material selection imho.
When I asked a learned colleague before posting my notes, that is where I gleaned the organic / inorganic information.If its got teats or tires, you bound to have trouble with it....
I recently dismounted a pair of twins, Yamaha 2005 V6, that the installer or perhaps the owner had filled all the unused mounting holes on the bracket including the remainder of the oval slots with silicone sealant.
When I asked a learned colleague before posting my notes, that is where I gleaned the organic / inorganic information.2000 Yamaha OX66 250HP SX250TXRY 61AX103847T
ÂÂÂÂÂ
