2008 F90TLR fitting leak
  • 2008 F90TLR fitting leak
    Motor is a 2008 F90. Can anyone tell me how this plastic elbow is sealed onto the cooling system cover? It has a slow leak from where it joins into the aluminum cover and I'm not sure how to remove it. I figured maybe it is press fit with an o-ring or something but it feels solid. Does the entire cover need to come off? Thanks for any help!
    Part #13? Looks to be replaceable...
    https://www.boats.net/catalog/yamaha...er-crankcase-1
    I'd order the part, once in hand, you'll see if there's threads / sealer, pressure fit, etc..
    Then remove yours as you now know how it attaches..
    *Added info, https://www.boats.net/product/yamaha...67e77f08487e5f
    It appears to push in, as for sealer, IDK, someone else will chime in..(Probably some sort of Yamaha sealer).
      If those are dissimilar materials like aluminum and some type of plastic then it may be repaired with epoxy or JB Weld....but looks like it may need removal to do it. Not much stress, pressure, vibration or heat there so I believe a repaire might work.....
        Its the larger fitting above part #13 made out of plastic vs the brass. It don't see a part number for it.
          Rodbolt suggested Loctite 518 at one point.
            It is not sold separately. Thus no part number. It is an integral part of item 12, the exhaust outer cover.
              Thanks. It must be bonded in and probably difficult to remove without breaking it. I may try and jbweld the seam from the outside and see if it will seal up otherwise try an remove it and possibly have to replace the cover.
                If you clean it up real well, Yamabond CASE SEALER (GRAY) will seal it up, no doubt (and easier than JB Weld-no running).
                There's a part # on the same page(#13), am I missing something?
                  Huh?
                    That part is the small brass elbow - like this one, shown on an F150:
                      did you guys miss what the OP said?
                      "Its the larger fitting above part #13 made out of plastic vs the brass. It don't see a part number for it."
                      it is right above the Brass nipple and right next to the #19, but the number 19 is pointing at the bolt
                        Not sure what you guys are seeing but the photo posted by the OP shows a circle around the part in question.
                          Huh?
                          HUH is right.
                          From the OP "Its the larger fitting above part #13 made out of plastic vs the brass. It don't see a part number for it."
                              I think by now Townsends will understand his error.
                              However - and nothing to do with the OP's problem -
                              some interesting history with that F90 exhaust cover:
                              for the years prior to 04/2006, that brass nipple was not there
                              [/url]
                              when it was added in 04/2006, the nipple was not called out as a replaceable part
                              beginning the following year, 04/2007 - it is:
