When I start it, it idles fine, after running it for a few minutes, it won't idle below 1800 RPMS. A couple of times today it did idle down but for the most part it stayed around 1800 rpms
High Idle 2002 T50
High Idle 2002 T50
Well, had no responses but I have been looking over the outboard. I had a yamaha dealer go thru everything including removing and cleaning the carbs. What they didn't do is replace the return springs on three of the carbs. That being said when I started it, it would idle but when I ran it up and returned the throtle back to nuetral the springs did not return the carbs back to idle. The simplest things.....
ÂÂÂÂÂÂÂÂ
