where do I find the drain plug on the Yamaha 703 70hp outboard thanks
yamaha703 70hp outboard
All I could find for the 1990's, 70hp are TWO STROKE engines. There's oil in the auto lube tank, in the lower unit. ???
Is it a four or two stroke, should be a model # on a plate on the side of the transome bracket.
If not snap a pic and post it...Scott
If it has a dip stick in the crankcase, usually yellow, and oil reqisters on the Hash marks on the stick, (Like your car), its a 4 stroke.
If it has a rubber looking drive belt running inbetween the crankshaft and two larger pulleys, its a 4 stroke.
The drain plug for the engine oil is usually recessed into a rubber tube, toward the rear of the engine. The tube would be angled outward and large enough to reach a socket in there (probably a 14mm).
For the 1985 models, I could only find a 2 stroke in the above fisch look up.
A picture uploaded from your computer would make things much easier....(Under the cowl hood)
Where/ what country are you located in?Last edited by TownsendsFJR1300; 07-06-2014, 12:39 PM.Scott
Well the two stroke part helps, tks...Originally posted by boscoe99 View PostA 6H3 prefix Yamaha is a 70 two stroke.
Carburetor drain plug?
Lower unit drain plug?
Oil tank drain plug?
703 is one model of a control box.
Guess its 20 questions time!!
David, if you could answer the above questions, you could get your answer...Scott
