My daughter bought a used boat with a Yamaha 200HP HPDI in February and has constantly had problems with the engine losing power. Her local marina mechanic has changed the thermostats, replaced the gaskets to the low pressure pumps and adjusted the cables. Each time he fixes something, the boat initially runs well but then develops problems. The motor sat for a while before she bought it and the engine has relation hours for a 2000 model.
She is getting very frustrated and starting to think she made a huge mistake buying an old boat. She just graduated from NC State last May and used most of her savings buying the boat.
As her father, I hate to think that each time she takes the boat out, she may get stranded.
Can a mechanic go through this engine throughly and replace whatever needs to be replaced and then expect this engine to be reliable again? Or is it just a matter of fixing things as they go bad? Or should she just buy a used 4 stroke engine?
I really appreciate your your advice!
Thanks, Chris
Thanks, Chris
