Hello, new to the site... I have a 2006 200 HPDI VMAX that I am having issues with. Issue - Started boat up after sitting for 4 months. Surging terribly at idle in and out of gear and would not go above idle while in gear. Any throttle at all killed the engine immediately. Drained all old fuel, new fuel line from 10 micron to motor, new primer bulb, all new filters (except mystery filters), new plugs. Started with muffs in the driveway and began surging again but then turned into a high steady idle at 1500rpm (even with muffs it usually goes from 1000 cold to 750-850 hot). Engine was rough at 1500 assuming because of idling on 4 cyl. Put a spark checker on each cylinder and all worked as should in gear and neutral. Took breather cover off and moved throttle link bar and engine settled to 1200 but still sounded more rough that usual. In gear still would not rev over idle. Checked TPS and noticed voltage would go from .68v at idle to a lower number instead of increasing with throttle. Tapped into wires and cannot get a 5v supply power reading with any combo of the 3 wires.
Over the winter I pulled new cables in the gunnel for adding fish finders. Is there anything I could have pulled loose in the gunnel to start this issue? I am only assuming that all sensor voltage is supplied directly from the Yamaha side and not from within the boat?
Any help would be greatly appreciated.
