Hey,
My 1978 Yamaha 6b outboard (6hp 2 stroke)
Has just started acting up, it runs great at idle but mid range it misses and jumps around. If you open the throttle flat it will rev up around half way and then you could wait maybe a minute (it varies a lot) and then it takes off up to full throttle and runs fine at that, but as soon as you let off it starts missing again.
Just wondering has someone come across this before?
I'm thinking it may be firing on one cylinder, maybe one coil on the way out?
Fuel primer is hard,
Fitted new spark plugs,
Fuel mix is spot on,
