Can you post exactly what parts link your looking at for the rest of us?
Ok, so when you push the key in for choke, your closing ALL the choke butterflys, correct?
So your enrichening the A/F mix momentarily....
I gather you confirmed fuel in the #3 bowl by pulling the drain screw (when the carb SHOULD BE FULL). Carb can be spotless, by no / not enough fuel to it, it won't work...
As posted, a broke/failing reed should be spitting fuel back thru the carb and it's pretty rare they fail (IME)..
You should be able to remove the reeds fairly easily to inspect them for wear, etc...
Might want to do a Leak Down test at TDC. Even thou a 2 stroke, any excessive leakage at TDC could indicate bad rings, bad head gasket, etc.
