Fuel Management Gauge stopped working
  • Fuel Management Gauge stopped working
    The fuel management gauge stopped working on mboat, I have a F225. the gauge reads 0 and does not move. Anyone have any ideas?
    The sending unit probably died. How old is it? There was actually a recall on the early ones (pre-97's ?). Does it run through the initial test when you turn the key on? If it runs thru it's self-test then the only other things to look at are the harness/plug and the sending unit itself. It should be installed on the outlet side of the fuel/water seperator. You can try cleaning it out just to see if it's got a gum or varnish buildup on it, who knows. Unless you can test it with another sending unit installed. Good luck.
    Mike ....... Miami, FL
      Thanks Mike. I will try your suggestion. It's only two years old and it goes through test mode ok.
