okay so the darn thing sounded the alarm on the muffs for the last time.
took the lower unit off and connected the garden hose to the water tube in the midsection "NO ALARM" took plugs out of the top of the cylinder heads and water shooting like old faithful thank goodness! put the plugs back into the heads and while the lower unit was still off I put the muffs on it and hot damn if the frickin water could barley make it to the bottom of the water pump housing. so I forcefully made the muffs seal around the lower unit better "IGOT GREAT WATER PRESSURE" and i'll tell you what they could have designed that alot better . I will not be flushing my motor on muffs any more . does anyone know if they make a flush kit to flush it with out running the engine? thanks.
