Sim Yamaha put out an instructional video"F225 Service Information VST Removal, Cleaning, Filter/Screen Replacement . I watched it and I was looking at frame 15 where it showed the routing of the fuel lines. How the lines are run is that correct? I am really talking about the cooler lines to the brass nipple on the VST. I tried to down load the picture but our site said it was to big.
Routing of vst fuel lines
I've seen those photos before
(IIRC that 'presentation' was done by a THT member)
but I never noticed that detail -
the hose with the steel 'El' is in a surprising location, right across the VST:
It actually looks pretty reasonable - but that is NOT the way it is routed on my F225TXRD :
nor in the Yamaha Service Manual:
my guess, that was not the first time that owner was removing the VST -
and on a prior occasion,
he re-assembled using a 'novel' placement of that hose
Originally posted by marchmadness View Postwhat does the fuel cooler do ? It cools unused fuel from the fuel rail?
Perhaps not needed, or much, at WOT -
but dropping down and idling after a hard run:
its hot under the cowling and the fuel isn't being consumed very fast,
that HP pump is just cycling it round and round....
Originally posted by marchmadness View PostThat’s why it’s recommended to idle before shutting down. So if the vst is full no “cool” fuel enters the Vst .why isn’t all the fuel run through a fuel cooler?
This is for the F150
(with dual mechanical lift pumps; the OP's F225 has instead a single electric lift pump)
If there is a EFI Yamaha where 'the VST pump' does not run constantly with any engine rpm,
I am not aware of it.
ÂÂÂÂÂÂ
