hello everyone , this is my first post .
i have a 1988 Yamaha 40 2 stroke 3 cylinder Autolube
last year it ran good , but. not 100% !
Started it up 1 week ago and it takes 3 tries almost every time to start.
once started it idles VERY rough . a low idle and then suddenly a higher idle and then a low idle , then "click" , "pop" and it dies . all of this happens in about 10-13 seconds from starting -
the motor does this religiously just after being started .
ive gauged the new spark plugs . new impeller and gaskets , new gas in a new tank.charged the battery and was all ready to go when the motor wasnt .
im not a mechanic .
but i have been trying to educate myself .
i tried un-plugging spark plug wire 1 and starting the motor .
it idles rough , and it's a click , pop and die .
the same thing with spark plug wire 2 un-plugged ( 1 & 3 connected ) -
when i unplug wire 3 ( with 1 & 2 connected ) it idles rough , but not as rough and doesnt die .
a bad coil ?
im positive the carbs should be cleaned out , but. what other things should be looking at , or considering . im heading up to the marina a few clicks from here to talk to a mechanic in the morning .
but i was hoping for some help from the Yamaha pro's here on the forums .
thanks for any help advice before hand
Cheers
im not a mechanic .
a bad coil ?
Cheers
