My 2004 F115 is leaking oil from the water intake on the lower unit. I am getting ready to replace the water pump. Will the two O rings that come with the water pump kit fix this problem?
oil leak
You need to determine the source of the leak first. Without knowing where the oil is coming from I don't see how anyone can tell you that the O rings will or will not solve the problem.
With the lower unit removed check the drive shaft. Is it oily at the top down to the water pump or is it oily from below the water pump.
The o rings that will come with the kit will not fix your problem, if it is engine oil it is running down the drive shaft from the oil pump.
You need to pressure check the gear case at 14psi. Did you have water in your gear case? Or did you check it?
+1 ^^.Originally posted by walleye1 View PostThe o rings that will come with the kit will not fix your problem, if it is engine oil it is running down the drive shaft from the oil pump.
The WP Kit seals the WP impeller housing, etc only.. It doesn't seal oil in the LU itself.
Also, when checking pressure, make sure the LU is EMPTY of oil.
