Hi there,
Well an auto electrician can't fault the electrics or the bbattery of the starting system.
He indicated that as it is an inertia drive starter motor the pinion gear spring may be too tight or tense alowing the ppinion gear to drop down as the motor begins to crank and takes the load of the spring. If it is too quick in releasing sometimes it may not start.
Sounds feasible?
How do you adjust the spring???
Regards'
Craig
Sounds feasible?
Regards'
Craig
