I am trying to resuscitate a 150 HP marine engine that has set up for several years after cylinder heads were pulled/reinstalled.
Tested Stop Circuit (OK no ground present at white wire to Control Unit w/ switch On). Pulling lanyard safety switch grounds white wire, however turning ignition switch to OFF gives 66 ohms resistance to ground.
Tested Ignition Charge Coils and got over 85V peak voltage on oscilloscope w/ spark plug leads shorted to ground and engine cranking over.
Tested two of six pulser coils (difficult to backprobe harness behind fuel vapor separation cannister) and got more than 2.5V w/ engine cranking and spark plug leads grounded. All tested about same resiistance from CU harness connector.
Tested Crankshaft Position Sensor output w/ engine cranking and got over 0.5V output.
Tested CDI/CU output four of the spark coils and got practically 0V while cranking engine and spark plug leads grounded.
Connected noid light w/ LED to Blu stranded lead and terminating Yel/Red at connector on Fuel Pump Harness and got one ~2 sec On flash then Off when keyswitch turned to On. I did not try to simulate a defect code to confirm I have interrogated CU correctly.
From the Clymer manual (Yamaha 115-250 HP, 1999-2002 Shop Manual) I'm using, it looks to me to be a faulty CDI/CU unit, but they caution this is relatively rare and to look for other faults. I have repeated testing twice w/ same results.
Question: What else could I test to confirm CDI is faulty?
thanks
thanks
