I am finally going to reseal my lower unit, so dropped lower this afternoon and cleaned it up before trying to open, and I am not real sure how you are suppose to pull the drive shaft seal housing below the water pump. It is plastic, and I do not see anything to get a hold of to pry on it.
I believe Rodbolt in the past said to drill small holes and run screw into the plastic shift shaft seal housing #14 to pry on when pulling that.
Is that how the driveshaft seals housing should be pulled also?
It is #31 in this parts breakdown,
notice they call it a water pump housing, just like they call #21 the real water pump housing
https://www.boats.net/catalog/yamaha...casing-drive-1
before I tear it apart I will rig up a pressure tester to see where I get any bubbles so I do not do things that are not needed.
also notice how #31 the housing is more expensive that #30 the assembly that includes the housing and seals
