150 TXRU. 1996 150 Saltwater Series Carb Motors.
Starboard motor is fine. Port engine no spark on any cylinder. Swapped ECU/ignition coils from good motor. Still no spark.
Have 12V on the white wire from ignition/kill switch with key on/engine off or cranking. I believe that is not good. Starboard motor has zero volts. Both motors' white wires ground with key off or kill lanyard pulled.
Disconnected 9 pin connector (with white wire) at ECU, still no spark.
I thought disconnecting the wire would eliminate the ignition/kill switch from the circuit.
Any one have any suggestions? I have the manual and I'm picking up a DVA adapter to continue diagnostics.
