Guages
  • Guages
    Hello, What is the proper guage to use with my 2008/9 90HP TLR 2 stroke engine? Is the an alternative guage (for newer OB) for use with an adapter?
    There are many gauges that will work with your motor. Yamaha analog, Yamaha conventional multi-function, and then there are aftermarket gauges.
    Yamaha will be plug and play. Some modifications might be needed if non-Yamaha stuff is used.
    What do you want? What kind of throttle/shift control box do you have? Side mount or top mount?
    Start here and you can see some Yam stuff
    2013-MRP-Catalog
    2013-MRP-Catalog
    2013-MRP-Catalog
      Thanks Bosco99, I have a side mount. The guy who did some work on my motor has a Yamaha Guage and the plugs dont match. I was wondering if it is compatible.
        may not be the correct year
          All of these gauges should be plug and play with a 2008/2009 Yamaha 90TLR. I have no way of knowing what gauge the fellow that did work on your motor has.
