Hello,
I have just purchased a new boat which has a 2005 150hp Yamaha 4 Stroke on the back. I found 2 plugs under the engine cowling not being used, I have attached a photo of each plug showing the wire colours. Hoping someone can assist where to plug these into, or if they are needed?
1 - the plug is a 4 pin, only 3 pins are being used. Pink/White, Pink/Black & Blue/White. These wires come from the outboard wiring harness.
2 - the plug is a 4 pin, only 2 being used. Green/Red & Green/Black. This cable runs from the multi-function gauge & I think this is does Temp & Oil. But where on the engine should these be connected?
I have seen these colour wires plugged together on some models & this could possible be my answer, but just want to confirm.
Tom
Tom
