What gauge and/or wiring kit to use? For 115HP 4 stroke
  • What gauge and/or wiring kit to use? For 115HP 4 stroke
    I am new to this form, so this is my first posting.
    I had a 1986 ProV 150 on my boat with the 4 inch tach gauge with oil level and other sensors on it. I replaced the ProV 150 with a 2012 115HP 4 stroke motor. The wiring harness and controls worked from the ProV and it runs and shifts fine. I want the replace the old tach gauge with a new digital one. But I need to know what gauge to get (part number) and do I need any special wiring for it?
    Get a single tachometer kit. Cheaper than buying just a tachometer. It will come with new wiring that will be run from the motor to the gauge and from the key switch to the gauge.
    2013-MRP-Catalog
    2013-MRP-Catalog
      SO?? Do I need ???
      Thanks for the info. But do I need all the wiring harnesses if I already have some from my old tach ?
        No.
        But if your trim/oil wire harness from the motor has round connectors on it you will need some expensive adapter harnesses.
        Then you will need a standalone tachometer.
        The standalone tachometer alone will cost you more than the kit with the updated trim/oil harness will. Add to that the price of the adapters. You will now have a brand new tachometer getting its data from an almost 30 year old trim/oil harness.
        Yamaha will appreciate getting your money.
          enough said!
          You are correct! Sometimes I just need someone to point out the little things to make sense of it? Thanks for all the help!
          P.S. I like my money more than Yamaha does! LOL
