Good morning all, I just had to replace my damaged gearbox on my 06 Yamaha F150tlr. I bought an aftermarket because i can't afford a factory part and now I can't get the water pump to prime unless I cover the whole top of pump. If I don't, it won't prime system. My old unit just needed the pick up screen covered. I replaced housing and impeller but still won't prime unless it's completely submerged. Any help would be greatly appreciated considering manufacturer is closed for holidays and I want to fish!!!!
Why no pee?
Originally posted by walleye1 View PostI think you are missing a part in the wp housing that seals the pick up tube.
make sure. My F150 needs a good bit of water to pee. Takes two hoses in the driveway.
Take it off and verify the grommet/rubber seal is in place where tube connects to pump housing. Take the boat out and get it up on plane and see if it still pees. Trim the motor also to
I believe it's part #2: https://www.boats.net/catalog/yamaha...casing-drive-2
My 06 F150 pee's easily on one hose, just on muffs, never an issue:
https://www.flickr.com/photos/147134...6/34909194323/Last edited by TownsendsFJR1300; 12-29-2018, 03:20 PM.Scott
Originally posted by Thomas Gillane View PostKill switch on the 703 control box has a plastic lock/jam nut to hold the switch. Anybody know the size and type of nut it is. Mine cracked and I can't find one at any of the big box stores.
Simply click "start a new thread"
https://www.amazon.com/Yamaha-Outboa.../dp/B002GUJM4CScott
From what I have read there are a lot of them like that.
hard for the pump to suck on air to get water up to it.
everything I have read says to submerge to cover water pump so you do not end up hurting the rubber impeller with it turning dry
everything I have read says to submerge to cover water pump so you do not end up hurting the rubber impeller with it turning dryScott
Plus 1 on the o-ring seal...
ÂÂ
