I have a 2000 Yamaha 90TJRY. I have had an intermittent problem for a couple years where the engine speed will drop form 5200 to 4000. It can run great for a couple weeks then one day it will decide to cut out. I can run indefinitely at reduced RPM. Seems like disconnecting the fuel line then running engine dry and repriming helps restore the WOT.
When not misbehaving the engine runs great.
After returning from Lake Erie a couple days ago where it decided to go wonky 3 out of 4 days, I have decided to try to figure out the problem.
This year have replaced all fuel line and components from the tank to the engine and added a fuel/water separator. I have vacuum/pressure tested the fuel pump and tests OK. I have tested the plug wires, and coils and seem to test OK. I have checked the wires in the engine compartment for shorts, and all look like new.
My thought at this point is dirt in a carb or all carbs since in hindsight the problems seems to occur mostly when running is rough water but not always.
Any thoughts would be appreciated.
