2004 Yamaha F225 Engine, 900 hours, running rough and not making top RPM. Today found water in cylinders 1 and 3, top two cylinders on starboard cylinder bank. Compression check OK, bottom cylinders dry, oil clear. Guessing head gasket? If not, any other guesses? guessing not exhaust plate corrosion as best I can tell the indicator of that is water in bottom two cylinders? Is that correct? If head gasket, can it be replaced at my dock? Most major repair I have done at dock is removing the injectors to clean them. If head gasket, could it still be corrosion related? Seems these engines can have major corrosion issues?
Thanks in advance to whomever can answer my questions!
