2001 F115 EFI Four Stroke. Bought a project boat here. Engine is running rough and stumbles when raising the RPM, but can get up on plane and run to WOT. Problem is when trimming the motor the rpm drops about 600-800 RPM. at idle its fine at 2,000-5,000 this happens.
So far I have done this.
Clean VST
Cleaned Injectors
New Batteries
New spark plugs
Tested Ground Wires and all Connections
ECM Peak Voltage 14volts at 750rpm No good
Resistance test on Stator Coil spec 0.2-0.8 reading .3-.6 Good
Stator Coil Peak Voltage Test- low voltage 1-2 and erractic readings No Good
Crank Postiion Sensor-Peak Voltage test - low Voltagle 1-2 volts
TPS Test 0.725
CPS OHMS spec 445-565 reading 0 no good.
Ignition Coil test in spec
Do I need to replace the CPS and Stator? Will the CPS and Stator effect each other? Is there any other test in need to do to confirm this.
Any help would be appreciated.
Thanks Guys
Clean VST
Cleaned Injectors
New Batteries
New spark plugs
TPS Test 0.725
Thanks Guys
