2006 f115 (68v-L-1055558). Been laying up on charger for 8 months during duck season. Did annual maintenance and drained fuel tank. On first trip out all seemed fine while running. After running about 20 minutes noticed alternator voltage was at 11.8V (normally 14.x V at high rpm's). Switched batteries and on restart same thing while running. Both batteries should be good. 1 a year old and the other 3 years old but runs *****ing motor fine. Came home and cleaned all electrical connections and grounds on batteries, battery switch, and engine. Sealed with corrosion block. Tested at home while running on hose and getting 13.v-14.x V. Ran for 15 minutes and same result. Thought all was good. Took out on trip and after 15-20 minutes of high rpm running same thing. Motor never stumbled or gave me any trouble except for low voltage reading ( it was throwing "low voltage alarm" via NMEA 2000 gauge hooked up). Figured time for some elec testing. Unhooked lighting coil plug from rectifier/reg and the plastic internals of the plug on the lighting coil fell apart. From the heat I assume. See attached pics. Resistance tested all 3 green (white) leads from lighting coil to themselves and all showed resistance of .8 ohm. Also checked ground of lighting coil green wires to ground and there was no short to gound. Manual says I need to really check lighting coil and rectifier/reg with special adapter while running and with a DVA neither of which I have. Plan on buying a new reg/rectifier (~$105.00) to start though I hate throwing parts at things. Will a bad reg/rect go out once heated and then return to normal once cooled down? Always in driveway on hose voltage is good, even now. Should I have to buy a new lighting coil (~$450.00) for the new plug internals. It seems to test out fine although I cannot do a running test. If I buy a new rec/reg and install it and the lighting coil is bad canl it blow that new rec/reg as well. Help!!!!! Ideas??
Sorry for the length but trying to include as much info as possible from the start.
