40HP won't start when its hot
  • 40HP won't start when its hot
    I have a 1999 40 that starts fine when its cold but doesn't even crank when its hot. I can start it using the pull cord or if I let it sit and cool down it starts.
    can we maybe get a model number?
    there was more than one model of a 40 HP in 1999.
      F40TLRX was wondering if it sounds like the CDI
        Could you tell us what you call crank
          It won't even try to start the starter doesn't spin
            Does the relay click but starter does not engage into the flywheel or even try to turn?
              No the relay doesn't click at all
                took you awhile to get back
                Time to get out the volt meter to see where you have voltage and where you do not while trying to start when the problem is there
                Key switch, start relay, and neutral safety switch are some places to start checking
                  I've checked all the safetys and the key switch everything checks out
                    sounds like you have a cooked engine
