I've got a 2007 2stroke 70, its while sitting overnight with the motor tilted up it leaks oil into the carbs and will smoke horribly when started. Recently went out and after running and smoking bad the engine cut off and was extremely hard to get running again. Pulled the air cleaner and upon doing so probably 2 tablespoons of oil came out. Any pointers before I start pulling the oil injection system apart?
70hp oil injection problem
