My motor is a 2001 200hpdi TLRZ and yesterday while on the water the tilt/trim failed. It won't raise. It does make the "bottomed out" noise when I hit the down part of the rocker switch. The same symptoms exist when I use any one of the 3 switches on board (upper/lower/cowling).
Checking prior posts I'm led to believe the problem may be the relay and I have two questions:
a) How do I test the relay?
b) If it is indeed faulty, will I need to buy the entire relay assembly or just part of it?
Thanking you in advance,
Tony in Tampa
Tony in Tampa
