I have a 1991 Yamaha 200 prov. Ran perfect for a few min. the started to run like crap then wouldn't run. Turns out there was a bunch of water in the fuel. Drained tanks, removed and cleaned carbs tried running it on a can of clean gas but it won't run right. also removed plugs and cleaned them. Please help
Yamaha prov 200 water in fuel
Besides the above, can you post some history on the engine, ie, is it new to you?
Did it sit for awhile without fuel stabilizer?
To your knowledge, has it ever run correctly?
When you cleaned the carbs, did you pull the jets physically out and inspect all the jets, that their fully open?
At the very least, drain the carbs (should be a drain plug) into a clean tuna fish can and inspect what comes out. IE water still, rubber parts from ethonol fuel damage, etc. If craps in there, keep pumping from your fresh fuel tank until you get clean fuel out of the bowls...Scott
Even thou you cleaned the carbs, some debris (as noted above) left in the fuel system may have made its way into the carbs.
At the very least, I would pull the carb drain bolts and drain the carbs into a CLEAN TUNA FISH can (so you can examine for debris/water). Maybe prime the bulb a couple of times to flush out any potential crap.
Make sure your internal YAMAHA fuel filter is nice and clean, no water and the cup is fully seated with a good gasket/o-ring. Any vacuum leaks in the system will cause havok.. Same goes for any external fuel filter.
May I ask how many hours, in your possession, it ran fine?
Your first post mentions several minutes..Scott
