I forgot I had this Yamaha bulletin (put out in 2005) re checking oil levels in ALL MODEL/ YEAR Yamaha 4 stroke engines(given to me at a Yamaha marine service dealership).
Besides tilting the engine to 45 degrees, their also having you wait an additional 5 minutes (after warm up) to check the oil level.
I wouldn’t think the volume would be much but would like your opinion. (I took two pictures so it would be easier to read)
Thanks...
Thanks...
), looking at parts fisches trying to figure out how Yamaha may have designed something, it is. In some area's, very different from the older Evinrudes. Yes, and engine is an engine, however,ie, trim and tilt electronics for instance, (speaking on the older Evinrudes) is completly different than the F150. A carb is a carb, with some differences, issues are usually the same, clogged main/idle jets from varnish/ crappy gas, etc. Cleaned many a Evinrude carb and many MC carbs also syncing multiple carb bikes using specific vacuum gauges (Carb Tune).
