And now onto my next mystery...
Have not had any issues this year with the motor. Been running great. But this week I had some intermittent engine shut downs.
Background/Story: The engine was running fine, got back to the slip for a pit stop, decided to go back out, and the engine wouldn't turn over. I noticed that when I turned the key to the on position, the VST pump didn't kick on. So I check the fuses and relay. fuses where good. Relay wasn't clicking. Decided to go get the tester to see what was getting power and what wasn't. Got back to boat from the tool shed, turned the key to on and the pump was working again. Motor turned right over. Everything was running good. Left the doc, ran out and got up on plane, motor shutdown again. Towed back to the doc.
Gave the engine a break for a few hours, (plus I had some errands to run) came back and the boat and motor turned right over again. But I wasn't going back out to test. Figured I should start by plugging into YDS to see if there is anything in the diagnosis and maybe run a few tests.
YDS plugged in while engine is not running: Engine Monitor Looks good.
YDS Plugged in while engine is running: Engine Monitor flips out.
You tube video here: https://youtu.be/v48757KOPTY
Is this normal for the engine Monitor to look like this while the engine is running??? After a few minutes, the connection errors out and I need to shutdown and reconnect.
Also, I can not run any active or stationary tests. YDS comes back and says the engine is running (when its not) or the engine is in gear (F or R). But its really not. And I am don't see that they shift sensor is malfunctioned.
Any thoughts and any help would be greatly appreciated.
My next steps are to start performing Electrical tests to see if there is anything wrong with the electrical components.
Thanks!
Thanks!
Yes I also set the PC comm port to one without anything plugged in. I probably was not clear in my statement that you can plug it all up to the engine and the laptop just not boot up the laptop until the key is on or the engine running.Normally once set the comm port will stay at one, unless you change it for some other reason, if set that way for future use.
