Last fall when I pulled my boat I noticed a leak. Over the winter I replaced one of the trim caps and its seals. I put it back on the boat today but it doesn't have enough power to go up. It will go down and if its tilted up enough it will go up slightly since there is less weight on it. When I had it up I checked the fluid, its up to the top of the reservoir however it looks like it has lots of little air bubbles. Does anyone have any suggestions on how to get this thing working again?
Trim and Tilt Issues
the wobbelator plate is what puts the wobble in a ducks butt
without any other information as to WHAT trim unit is being discussed its all I could come up with.
there are at least 8 trim units used by Yamaha over the years and models.
Originally posted by rodbolt17 View Postthe wobbelator plate is what puts the wobble in a ducks butt
there are at least 8 trim units used by Yamaha over the years and models.Scott
1998 L250TXRW Yamaha Outboard POWER TRIM TILT ASSEMBLY 1 Diagram and Parts
Are you topping off the reservoir with ALL the rams EXTENDED (and the engine raising and sitting the mechainical linkage?
Also, make sure the "manual release" screw, part #34, starboard side (that releases your engine to go down should there be an issue is tight. If its slightly loose, the pump won't build up pressure and raise the engine..
BTW, there's only 4 models for that year and HP....Last edited by TownsendsFJR1300; 04-16-2014, 07:39 AM.Scott
Well no good on the bleeding by manually pumping up and down. So I took the T-n-t back off, plopped in on my bench and started poking around. I pretty sure I found the problem. The small snap ring on the manual release valve came loose so the valve wasn't closing properly. Unfortunately the parts arent looking too good so I'll have to wait for the new parts to come in before I can claim victory.
Originally posted by brielly1 View PostWell no good on the bleeding by manually pumping up and down. So I took the T-n-t back off, plopped in on my bench and started poking around. I pretty sure I found the problem. The small snap ring on the manual release valve came loose so the valve wasn't closing properly. Unfortunately the parts arent looking too good so I'll have to wait for the new parts to come in before I can claim victory.
A pain to remove the unit but you found it. Parts should be pretty cheap. Just saved several hundred $'s!!!Scott
Good.
Just a side note, if the original clip was stainless steel and exposed to the water, I'd make sure I replaced that clip with the same material.
You don't want it rusting out on you if its not the same, not plated, etc...Scott
ÂÂÂÂ
