Just wanted to say this is my first post and first Yamaha motor. I just bought a 9.9 high thrust remote motor got it home and it has a 10 pin wire plug conector male end so I was bumbed I couldn't start it up . It going on a 18 foot boat with front steering so I ordered a 30 foot 10 pin female wire connecter. Only prob is when I got the 30 foot cable it y's off at the end to two plug conecters I only want a key switch and a trim switch up front so what wires do I use and what wires do I not use im going to cut off the conecters at the y end
Need help with wire harness
It is too bad that you did not provide the complete model of the motor in question nor did you provide the type of control box that you will be using. It makes a difference.
The Yamaha ten pin harness with two connectors at the help end is designed for the 704 control box that uses a remote key switch panel. For motors that have power trim and tilt. It would be wired as follows
Im guessing the end with the white insert goes to the key switch because there is six wires going to it and the key switch I bought has six prongs so the solid black end must have the trim tilt wires does any one know what color wires I hook up to the toggle switch for that
ÂÂ
