How come thees gear cases get heavier every year?
Gear cases
Never had many issues installing the lower. Until the last time. Tried four times to line it up and had to set it back down on ground. Hot. I was dying. I finally put a strap on it to catch my breath. Will always use it moving forward.Originally posted by walleye1 View PostHaHa, I do remove the prop also. I use a ratchet strap to hold it while lining up every thing.
Tim Baker a service rep for yamaha showed me that trick, got to use your head though.
Some Yamaha models may have studs in the lower casing, with nuts holding on the LU
but my F225 has bolts -
so I made up a couple of "temporary locating studs"
I put them in finger tight when I am ready to re-install the LU
makes it a breeze to get the line up / angle of attack when sliding the LU back in
and then takes the weight while I am lining up the shift shaft
once I have one or two of the bolts in, I back out the "studs"
That sir is a good idea...Originally posted by fairdeal View PostSome Yamaha models may have studs in the lower casing, with nuts holding on the LU
