How come thees gear cases get heavier every year?
Gear cases
Originally posted by walleye1 View PostHaHa, I do remove the prop also. I use a ratchet strap to hold it while lining up every thing.
Tim Baker a service rep for yamaha showed me that trick, got to use your head though.
Some Yamaha models may have studs in the lower casing, with nuts holding on the LU
but my F225 has bolts -
so I made up a couple of "temporary locating studs"
I put them in finger tight when I am ready to re-install the LU
makes it a breeze to get the line up / angle of attack when sliding the LU back in
and then takes the weight while I am lining up the shift shaft
once I have one or two of the bolts in, I back out the "studs"
Originally posted by fairdeal View PostSome Yamaha models may have studs in the lower casing, with nuts holding on the LU
Â
