I am looking for a stator part number 6H0-85510-01-00 and everything I find says it is not available. I have found a couple of sites that have a 6H0-85510-03-00 but nothing saying the original part crosses over to this one. I was hoping Bosco or some one would be able to tell me if it does indeed cross. This is for a 1997 80 HP 2 stroke. Idont have my serial number handy but I can get it later if needed,
Cross reference number
I think the -03-00 will work. Here's why:
A 1997 90TLRV used a 6H0-85510-01-00 stator assembly (same as a 1997 C80), a 6H1-W0090-43-4D block, a 6H0-85550-00-00 rotor, a 6H0-85580-01-00 pulser coil and a 6H2-85895-01-00 crank position sensor. Also all used on the 1997 C80.
A 2001 90TLRZ used all of the same parts except for the stator assembly. It used part number 6H0-85510-02-00. The -02-00 stator assembly has been replaced by a -03-00 stator assembly.
The -03-00 stator assembly works with all of the other related parts that are used on the 1997 C80 model. Therefor, it should be form, fit and function interchangeable with your -01-00 stator assembly.
If you look at Rodbolts explanation a couple of posts ago, he explains how yamaha part numbers work. 1st number is the model of motor that part was first used on, 2nd number is the part description, 3rd number is the revision number for same part, and 4th number is paint code if applicable. Using that, it should work perfectly. Please correct me if I got that wrong.
In 99.9% of the time a -01-00 will work for a -00-00 and a -02-00 will work for a -01-00, etc..
It is the 0.1% that can get you.
Originally posted by rodbolt17 View Postor
simply order the original part number and Yamaha will send the latest version.
Ever heard of Victor Ray at Yamaha US? He was THE parts man there. When he left (retired) he took tons of information in his head with him. He had one hellava memory.
It is gonna be like that at Joe's Marine with Rodnut retires to Venezuela.
I guess they still have internet in Venezuela. Rodnut will have to offer his advice and counsel (and cryptic comments) from there.
Originally posted by boscoe99 View PostI guess they still have internet in Venezuela. Rodnut will have to offer his advice and counsel (and cryptic comments) from there.
I believe a loaf of bread is about $1200 with the inflation. All that oil and suffering.
It is great until you run out of other peoples money.
Boscoe, thank you for your input. I did contact CDI and they said that stator was a repair and return item only they didn't have a cross reference either. I asked them about the 03 and they couldn't confirm that it was a replacement. I guess I will be sending it off for repair.
No one is going to stick their neck out and confirm that the -03-00 stator assembly will work. I would bet my money on it if I needed one. Having said that, if CDI can repair your stator assembly then that is one way to go. Might even save some money.
ÂÂÂÂÂÂÂÂÂÂÂÂÂÂÂ
