Have a cylinder that appears to be dead. Has good fire, switched coils, switched out cdi, new fuel pump, rebuilt carbs, checked reeds,
has good compression. After rebuilding carbs runs much better, idles fine now but when I pull the plug wire off that cylinder(#4) no change in engine performance. Is this common or should I notice an engine change like I do on the other cylinders? If so what else could be the problem?
