Hey folks,
I did a search before posting and think I found my problem to be one of two things.
History: Just bought boat. Had cooling issues. Dealer replaced everything (pump housing, impeller, thermostats, sensors, pressure reg. spring. It has run well for two weeks of almost daily use. Today, the temp alarm went off twice at speed. I instantly look back and no pee stream. Once at idle all returns to normal. Starting it and stopping it several times brought the pee stream back. I made a couple of runs at speed and all seems well.
So... I read two posts talking about what happens if you get sand or pebbles in the system; they hang out in the pressure reg valve and cause troubles.
In one of those posts it was mentioned that a certain hull design can starve the intakes in a turn.
Well, I have both conditions. I live on a river with Gulf access. It's tidal with shifting sand bars everywhere. I was *****ing the night before and scrubbed up on one, basically blasting reverse to get me away. I was trimmed up, but the mud did stir. So it could be the sand in the valve.
BUUUTTTTT, I have a 20ft Century with deep channels in the hull design which do inject a lot of air into the water on each side of the lower unit. And both times it went off I was in long sweeping turns. (yes I was trimmed properly).
So a couple of questions. Either way I've had the motor turning at high rpms when either the intakes sucked air, or the pressure valve shut down.
Given that water had just been flowing (verses starting the motor of the trailer after it's been sitting a month), how much of this starved condition does it take to wipe out an impeller and/or pump housing?
And is there a way to toughen up the system for us river rats? We can't always come and go on the high tide!
And any step by step for getting to and cleaning sand out of a pressure regulator valve would be appreciated.
Thanks so much,
Steve
Thanks so much,
Steve
