2005 F90 TLRD Timing Belt
  • 2005 F90 TLRD Timing Belt
    Can anyone advise if someone has posted how to change the timing belt on 2005 F90? If not any suggestions or tips ?
    A service manual for that motor will have the steps and specs.
    And list any tools needed
      I believe the flywheel has to come off, so a large socket, puller, etc.
      I wouldn't do it without the manual, the marks cam and crank, have to be dead on.
        I do have the manual just wanted to get a general feel for what I'm considering taking on.
        Thank you
          If you have the manual, it should be explaned pretty clearly.
          You might try searching "You Tube" for a video to re-enforce what the manual states..
          Good luck.
