Hi guys,
I have a '98 Yam. 70 hp 2 stroke.
Started it up and no smoke at all.
quickly pulled an oil line off, no oil coming out.
Shut down.
Cleaned out the check valves. No obstructions.
Restart, no smoke, pulled line from before check valve, no oil. Quickly shut down.
Is there any way to test the pump?
Could the feed line to the pump be clogged? I'll check this next.
How do I remove the pump?
Is the pump electric? Don't see any wires...
Any help, info or insults would be appreciated.
Marco
Shut down.
Marco
