The tilt lever seems to hang up. the bushing around the shaft seems swelled under the lever. The lever does move it needs help and does not spring back up. It has to be moved up to lock. To change that I see the tilt tube must come out. If that is the solution to change the bushing how do I get the tube out. Is there a puller for that.
Thank You for any advice
