Hey guys i have had a few issues with my tach recently. The tach was sounding a constant alarm when key turned on than it kept sounding when engine was turned on (no symbols flashing etc.) Got it up on the plane for approx 2 mins before it went into limp mode, turned off than back on all good. Probably after another 5 mins of running the tach stopped working and just reads 0rpm, engine hours are also frozen and have not changed. Also the engine will continue to go into limp mode at random times. Has anyone had a similar issue? I dont have a multimeter to check wires etc but can get one
Tach reads 0 rpm goes into limp mode
it seems you may be referring to a Yamaha digital display "multifunction" gauge
i am not aware of any version which is capable of sound
(horn is usually on the keyswitch or control box)
what year / model Yamaha is this?
btw I must say, I am impressed with the troubleshooting technique
of running with the alarm sounding to get up on plane
Originally posted by jaredluke View PostHey guys i have had a few issues with my tach recently. The tach was sounding a constant alarm when key turned on than it kept sounding when engine was turned on (no symbols flashing etc.) Got it up on the plane for approx 2 mins before it went into limp mode, turned off than back on all good. Probably after another 5 mins of running the tach stopped working and just reads 0rpm, engine hours are also frozen and have not changed. Also the engine will continue to go into limp mode at random times. Has anyone had a similar issue? I dont have a multimeter to check wires etc but can get one
There is no Yamaha tachometer that has an audible alarm capability.
Yes, other people have had similar issues as those that you describe.
Care to share with us which model Yamaha you are talking about? They are not all the same. There are some minor differences between some Yamaha outboard models.
the 1999 70 does NOT have the feature that sounds the horn with the lanyard removed.
if your using the 703 control box DO NOT plug the two gray wire together under the hood.
if you do you get an audible at key on.
maybe knowing what tach you have and which control box would help us help you.
ÂÂÂÂÂ
