So my F225 txr"d" Drove me crazy today. Last night the over heat alarm would go off at idle speed. The temp wasn't over 190 on my MFD. So today I narrowed down which themo it was. Starboard side and figured it was the switch. It wasn't, I guess it was the 2 month old thermostat. It was stuck closed cause that head to get hot.
More strange f225 cooling issues
Did you test the thermostat? 2 months old and failure is not typical.Originally posted by Keith Ohanesian View PostSo my F225 txr"d" Drove me crazy today. Last night the over heat alarm would go off at idle speed. The temp wasn't over 190 on my MFD. So today I narrowed down which themo it was. Starboard side and figured it was the switch. It wasn't, I guess it was the 2 month old thermostat. It was stuck closed cause that head to get hot.
Can’t remember. Did you replace the exhaust stack?Last edited by pstephens46; 06-30-2018, 05:37 PM.
The exhaust has not been done yet and still looks good. The PRV was just replaced . First ride with it and noticed more than normal water coming out of the exhaust. When I pulled the stat I flushed it for a while. Put it back together and it would only get to 150 at idle in gear. 190 on plane at 5100 going 40mph. Also noticed no water coming out of the exhaust. What 99yam40 said sounds like what happen.
Yes I was. Yesterday everything was normal.Originally posted by 99yam40 View Postmaybe the OP is talking about the idle relief exhaust ports
main exhaust exists thru the prop, and that should be under water
Rod said the PRV is not a normal problem on those motors, so I hope yours is fixed and it is not the exhaust stack
