need help i have a 1999 yamaha 200 vmax 200 3.1 fuel injection the gromment broke for the oil injection i am going ti try to replace it my self it has treads for adjusting it how do i go about ajusting it thanks for your help
oil linkage
Part #20 or 23? or ?
1999 V200TLRX Yamaha Outboard OIL PUMP Diagram and Parts
If its just a screw on fitting, taking a very accurate measurment from eyelet to eyelet of the old and then adjusting the new end (screwing in or out) to be exactly the same, should do it...Last edited by TownsendsFJR1300; 03-24-2014, 08:16 AM.Scott
A Yamaha service manual for your motor will give you the steps and procedures needed to set it correctly for your motor
Here is something I found posted about it but do not know what motor it is for and it does not include all of the info needed
http://www.yamahaoutboardparts.com/a...adjustment.jpg
This is an important adjustment.
Back out your idle adjustment screw until butterflys are fully closed. Connect the oil rod to the carb. Bare in mind that a safety feature is that the oil pump goes into full oil delivery if a connector breaks.
Move the oil pump lever fully forward and attach to the rod.
This is my adjustment on my motor. It should be close to yours.
I would NOT eyeball it. Could be expensive.
Yes, after all else fails follow the instructions.Originally posted by 99yam40 View PostA Yamaha service manual for your motor will give you the steps and procedures needed to set it correctly for your motor
rather than dinking with the shutter stop screw simply unclip the bottom two shutters.
make sure the bottom shutter that drives the oil linkage is FULLY closed.
adjust the new clip so that with the shutter fully closed the clearance between the oil pump arm and stopper pin is .005-.020".
reclip the shutters and go play.
yes Virginia, its that simple.
