I disconnected my oil tanks so that I could mix fuel/oil myself. Is there any specific wiring I have to do so that my boat doesn't go into limp mode. Or bypass oil sensors so that my alarms are disabled? 1994 yamaha 130s twin
Oil Tanks Disconnect
Which floats?...sorry I'm new to this. The oil tanks attacked to the engine are out...I removed them along with any connections. How do I trick the system?
Blue/green stripe,Blue/red stripe,Blue/white stripe are the 3 wires need disconnected
LoboJim this is what I would do but proceeded at your own risk. Hope this helps Lobojim
ok
I cant stand it.
I gotta ask.
WHY would anyone remove the most bullet proof dead nuts reliable variable ratio oiling system ever built to premix?
most oiling system mechanical failures I ever see are with premixed motors.
ÂÂÂÂÂÂÂ
