Help!! I just changed all seals and o-rings on all three pistons of the power trim on my 175 Yamaha. I am attempting to fill with oil but have a major air problem. How must I fill with oil to eliminate all the air. Thanks for any advice.
Filling power trim with oil
I believe all three pistons need to be fully extended to top off the fluid. The engine should be held up by the mechainical linkage when doing so. Trimming up and down once most/all the fluid is in should flush out any air..Originally posted by WhitePerchHunter View PostHelp!! I just changed all seals and o-rings on all three pistons of the power trim on my 175 Yamaha. I am attempting to fill with oil but have a major air problem. How must I fill with oil to eliminate all the air. Thanks for any advice.Scott
